1995 Pontiac Sunfire
BCORYM06
  • 1995 PONTIAC SUNFIRE
he drivers side window goes down fine but then will only go up about a quarter of the way, if I drive around or leave it alone for a while it will go up alittle more and I can continue to do this until it goes all the way up. If I only put the window down a couple inches it goes back up fine.
Saturday, September 5th, 2009 AT 12:44 PM
  • 109,858 POSTS
Chances are it is the switch. WHat you need to do is remove the door panel and check to see if the motor is getting power when it won't go up. IF it isn't, replace the switch. If it is getting power, make sure the connections are clean and tight. IF they are, replace the motor.
Monday, September 7th, 2009 AT 10:47 PM
