timing
PONTIAC SUNBIRD
RYAN18
[/i]pontiacsunbird1994 4cyl replaced crank ,cam how to set timing.[/url]
Dec 19, 2006 at 10:07 PM
CANVIS69
  • 131 POSTS
Well, if it is a electronically controlled unit, you don't. For every thing else, you align the distributer to the TDC of #1, install it,(so it's timed to zero), and turn the distributer so the timing is right. But.....
I think most Pontiac's by 94 are electronically controlled. If the Hall effect and related sensors are properly installed it times itself. And, with a new crank and cam, it should all be relatively dead on anyways.
Dec 22, 2006 at 8:22 AM
