94 Pontiac Sunbird 2.0 L, leaking antifreeze
1994 PONTIAC SUNBIRD
STEVELUTZ425
Leaking antifreeze from front of engine. Is there a bypass hose on this SOHC engine or can it only be from the waterpump?
Jan 9, 2006 at 11:48 AM
2CARPRO JACK
  • 11,533 POSTS
look below the pump and see
Jan 10, 2006 at 9:51 AM
SPADE007
  • 37 POSTS
[quote:b8c05d52f1="stevelutz425"]Leaking antifreeze from front of engine. Is there a bypass hose on this SOHC engine or can it only be from the waterpump?[/quote:b8c05d52f1] if its leaking at the bottom of timing belt cover it is your water pump
Mar 18, 2008 at 6:02 AM
