1994 Pontiac Sunbird separating engine from transmission
1994 PONTIAC SUNBIRD
125,000 MILES • 4 CYL • FWD • AUTOMATIC
PARTDOCTOR
I have checked the service manual to make sure all bolts have been removed. It acts like the engine and trans have grown together with age, I have never had this problem. What am I missing? Is there a trick?
Apr 5, 2010 at 3:16 PM
  • 110,244 POSTS
Have you unbolted the torque converter? It may be binding. Also, are you sure the guide pins are not binding if you have upward pressure on the engine?
Apr 26, 2010 at 6:47 AM
