1994 Pontiac Sunbird hot start problem
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNBUCKNAM
my 94 sunbird in the past 6-8 months...I'll drive somewhere Go in for 10 - 60 minutes, come out try to start my car and get no crank,noise nothing whatsoever..everything else works..all the lights on dash that should be lit are and all that shouldnt, are not..I noticed it will start like nothing was ever wrong after the temp gauge bottoms out.. but it was never hot or close to hot to begin with.I dont even know where to start..oil is good water level is fine, I gave it a tune up and it made no difference..everything works well when its running..its a great car up to this point what do I do now.
Jun 20, 2010 at 7:28 AM
SATURNTECH9
  • 30,869 POSTS
First thing i would do is make sure your battery cable's are clean and tight.Also have your battery and alternator tested just to be on the safe side.Also do you have a multimeter we can do some test's when it doesn't start?
Jun 20, 2010 at 3:48 PM
JOHNBUCKNAM
batterys new. alt and bat tested fine.. someone said it could be a heat soaked starter..is there such a thing I never heard of it and if so what to do.
Thanks John
Jun 23, 2010 at 12:42 AM
SATURNTECH9
  • 30,869 POSTS
What they mean by heat soaked starter is just when it get's hot the winding's of the starter fail or the solenoid stick's or fail's.Good possibility it could be the starter though.But we will have to test it when it doesn't start to make sure that's what it is.So do you have a multimeter?We will need one to do some testing when it doesn't start.
Jun 23, 2010 at 4:53 AM
JOHNBUCKNAM
yes,I have a multi meter.
Jun 24, 2010 at 12:50 AM
SATURNTECH9
  • 30,869 POSTS
I emailed you the trouble and wire diagram for your starter to your personal email.You will have to do the trouble tree when the car is hot and doesn't start.
Jun 24, 2010 at 7:34 AM
