The brakes failed on this car. when I press on the brake pedal it goes clear to the floor with little resistance. I replaced the master brake cylinder and a broken brake line. This did not fix the problem. The action on the brake pedal is the same. What else would cause a complete failure of the brake system?
Apr 24, 2009 at 6:02 PM
