1994 Pontiac Sunbird ENGINE
186,000 MILES • 6 CYL • FWD • AUTOMATIC
TABETHA13
HELLO,
MY CAR IS HAVING VERY SERIOUS ENGINE PROBLEMS. FIRST MY CAR DOES NOT OVER HEAT, BUT IT DOES LET OUT WHITE SMOKE FROM THE EXAUST. THE QUESTION IS WHAT MAY BE WRONG WITH THE ENGINE, IS IT THE VAULVES OR THE INJECTORS, WHAT IS THE AVERAGE COST OF SUCH REPAIRS, AND WHAT SHOULD BE DONE?
THANK YOU.
Dec 21, 2009 at 5:45 AM
  • 110,248 POSTS
Actually, the white smoke indicated there is coolant getting into the combustion chamber and being burned with the fuel. If this is the 3.1L V6, chances are you have a bad head or intake gasket.
Mar 8, 2010 at 2:40 AM
