1994 Pontiac Sunbird brakes leaking
1994 PONTIAC SUNBIRD
WANDAH
Brakes problem
1994 Pontiac Sunbird 6 cyl Manual 190,00 miles
My questions is this--what happens if you lock off the rear brake lines and just use the front brake lines?
Will that work?
thanks
Apr 20, 2008 at 12:27 AM
BLACKOP555
  • 10,386 POSTS
well, it wont leak and the front brakes will function properly but!
if you try to stop you will loose control, your front end will probably drag the pavement also, and you will crash the vehicle.
the back breaks help you stop and most importantly stabilize you when doing so.
Apr 20, 2008 at 1:59 AM
