1994 Pontiac Sunbird Blue Smoke
1994 PONTIAC SUNBIRD
BBSUNSHINE
Engine Mechanical problem
1994 Pontiac Sunbird 4 cyl Two Wheel Drive Manual
Just recently I replace the oil and filter in my car with 80% LUCAS engine oil treatment. A week later while driving down thru the rocky mountains and contantly gearing down, my car started to blow some blue smoke, then alot of blue smoke. Now it is blowing White and blue smoke although engine poerformance has not been affected. I am trying to determin if I blue the engine, the head gasket or could the drain back holes just be clogged. The smoke only blows when I accellerate... and gear down.
thank you
Sep 14, 2009 at 10:42 AM
  • 110,244 POSTS
80% of Lucas isn't recommend. I believe you add one quart with the oil change. As far as the smoke, it sounds like you blew a head gasket. I would recommend doing a compression test to see if there is a bad cylender.
Let me know what you find.
Mar 8, 2010 at 5:58 AM
