1994 Pontiac Sunbird 3.1L
MARTESC
I have a 1994 POntiac Sunbird 3.1L. I have two problems with it.
1- One week ago, the car stop to work. The problem is that the car start to run some minites and then the motor stop. One friend to me that this is a problem with the computer. What your opinion?.
2- The other problem is that the car blow out the coolant and the motor temperature become high. I performed and inspeccion and not leaks is observed.
May 11, 2006 at 11:40 PM
LOSONE
  • 1,616 POSTS
You have a major engine problem. It sounds like you have a blown head gasket. Don't drive it or more damage will occur. Good luck
May 12, 2006 at 7:01 AM
