Engine Mechanical problem
1994 Pontiac Sunbird 4 cyl Automatic 102000 miles
i have a 1994 sunbird le 4 cylinder when driving if i come to a quick stop it stalls and doesnt want start for few minutes. i was told it was a oil sensor but the oil in car is full. i was also told it was some other sensor that is located on the manifold and this sensor has little piston in it. i was told take that particular sensor off and clean with carb cleaner and not mess with piston on it or it wouldnt be no good. i dont remember what that sensor is called. so what do you think the problem is?
Jul 7, 2009 at 10:40 AM
