1993 Pontiac Sunbird Clearing the code
Electrical problem
1993 Pontiac Sunbird 4 cyl
My OBD is telling me that I need to clear the codes manually.
How do you do this?
Jun 3, 2010 at 1:04 AM
HMAC300
  • 48,601 POSTS
pull the ecm fuse for 30 seconds that will reset it or should. If that doesn't work disconnect the battery for the same time. If you disconnect the battery you will have to reset everything.
Jun 22, 2010 at 10:23 AM
