1993 Pontiac Sunbird blinking lights
1993 PONTIAC SUNBIRD
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
RANGEL
I replaced the fuses and flasher, since my turn blinking lights were not working. the new fuses are getting burned. Can you tell me why? How can I fix this problem so that my turning signal works again.
Nov 28, 2009 at 8:23 AM
  • 110,240 POSTS
This is a tough one because there is a short, but to locate it is the difficult part. Does it blow after you turn the signals on or as soon as you replace the fuse?
Mar 8, 2010 at 5:29 AM
