1992 Pontiac Sunbird wont even turn over.
1992 PONTIAC SUNBIRD
CAROL1960
Engine Mechanical problem
My car doesnt start.. the battery has been replaced, the cables are fine. carb seems to be working, fuses are fine. it has gas!!
Worked fine all day yesterday, no problems before. It just decided not to start today.. Help!!!!!!!
Mar 19, 2010 at 8:58 AM
JDL
  • 16,098 POSTS
Your saying, it won't even crank? I'd have to make sure the battery has a full charge. Next, I'd check the starter circuit. If this is an automatic, did you try cranking in neutral? The purple wire at the starter solenoid should be hot with the key in the crank position.
Mar 19, 2010 at 9:36 AM
