1992 Pontiac Sunbird timing marks
BOBNKIM
Engine Mechanical problem
1992 Pontiac Sunbird 4 cyl Front Wheel Drive Automatic
when settin the time on the motor after changing the timing belt how do i line up the marks? do all the marks line up at the top?
Jul 2, 2009 at 6:09 AM
BMRFIXIT
  • 19,053 POSTS
Install rear cover (if removed).
Start all rear cover bolts before tightening to specification.
Ensure mating surfaces are clean, and install timing belt tensioner.
To install camshaft and crankshaft sprockets, reverse removal procedure. Tighten bolts to specification.
Rotate crankshaft and camshaft clockwise to align timing marks on sprockets with marks on rear cover. Install NEW timing belt on sprockets. Ensure belt is under tension between camshaft sprocket and crankshaft sprocket.
NOTE:Adjust timing belt with engine coolant temperature at 68°F (20°C).
Using timing belt tension adjuster, rotate water pump clockwise until tensioner contacts high torque stop. Tighten water pump bolts slightly.
Using crankshaft sprocket bolt, rotate engine clockwise 2 revolutions to fully seat timing belt. Rotate water pump eccentric counterclockwise until hole in tensioner arm aligns with hole in base.
Tighten water pump bolts to specification.
Ensure tensioner holes remain aligned and timing marks are aligned.
link to fighttps://www.2carpros.com/diagrams
Jul 10, 2009 at 9:48 PM
