1992 Pontiac Sunbird sputtering and accelleration
1992 PONTIAC SUNBIRD
207,000 MILES • 4 CYL • FWD • AUTOMATIC
ASHJOW
  • 5 POSTS
my car does this sputtering thing when you put your foot on the gas and you can put it to the floor and still won't go over 20mph. we have changed the coil pack, fuel filter, and spark plugs and wires, what could this possibly be.
Jan 5, 2008 at 11:00 AM
MASTERTECHTIM
  • 4,750 POSTS
is the vehicle running on all cylinders at idle. if yes you could have a restricted cat converter. the easiest way to check is to remove the o2 sensor and see if problem goes away.
Jan 5, 2008 at 11:03 AM
ASHJOW
  • 5 POSTS
do you know where the o2 sensor is located on this car...we disconnected the exhaust from the manifold and it still did it then we disconnected what may have been the o2 sensor but not sure where the o2 sensor is located, and then it idled perfect but again when would put on the gas it would sputter
Jan 5, 2008 at 11:16 AM
MASTERTECHTIM
  • 4,750 POSTS
ok problem is not restricted exhaust. have you tried spraying starting fluid into intake when it bogs to see if it clears up.
Jan 5, 2008 at 11:45 AM
ASHJOW
  • 5 POSTS
no we have not? why what else do you think it could be?
Jan 5, 2008 at 11:48 AM
MASTERTECHTIM
  • 4,750 POSTS
low fuel pressure??
Jan 5, 2008 at 11:49 AM
ASHJOW
  • 5 POSTS
is there a camshaft sensor for this car? when i look for the parts online there is a crank shaft sensor but only for a 3.1L v6...
Jan 5, 2008 at 12:21 PM
MASTERTECHTIM
  • 4,750 POSTS
no cam sensor
Jan 5, 2008 at 12:34 PM
