1992 Pontiac Sunbird Fixing water pump
AVALONANGEL
Engine Cooling problem
1992 Pontiac Sunbird 4 cyl Automatic 262000 miles
Hi I was wondering what metric system I use for the socket wrenches I need to buy, Imperial or Metric, to fix my water pump? Also if there is any other tools I may need? I am in Victoria BC Canada
May 14, 2010 at 3:42 AM
FOURTRAXHONDA300
  • 5 POSTS
buy a standard metric socket set, with sizes 8mm - about 19 mm in your case. the ratchet that comes with it should be atleast 3/8 drive.
Jul 29, 2010 at 8:53 AM
