1992 Pontiac Sunbird cooling fan
1992 PONTIAC SUNBIRD
225,000 MILES • 6 CYL • FWD • AUTOMATIC
LMACK65
  • 14 POSTS
cooling fan always running. what would make this happen?
Jan 5, 2008 at 10:03 AM
MASTERTECHTIM
  • 4,750 POSTS
is it running when the car is off.
Jan 5, 2008 at 10:04 AM
LMACK65
  • 14 POSTS
no, only when engine is running
Jan 5, 2008 at 10:07 AM
MASTERTECHTIM
  • 4,750 POSTS
you probably have a coolant fan switch that is reading too hot. off the top of my head its either a one wire sensor with a green wire going to it. or its a 2 wire sensor by the thermostat housing with a yellow and a brown wire going to it. you can find out for sure by asking your part store for a cooling fan switch. very cheap money. if its not that then your cooling fan relay is stuck on, also very cheap money, good luck.
Jan 5, 2008 at 10:15 AM
LMACK65
  • 14 POSTS
Thank you for your help, i will give it a try
Jan 5, 2008 at 10:17 AM
