Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Sunbird
Electrical
Ignition Switch
Key
1991 Pontiac Sunbird ignition switch
1991 PONTIAC SUNBIRD
135,000 MILES • 4 CYL • FWD • AUTOMATIC
LDREWJ
MEMBER
1 POST
How do I replace the ignition key lock on this car. Broke key off.
Nov 29, 2008 at 1:46 PM
BUDDYCRAIGG
Experienced Mechanic
i have pretty good luck pulling the key out with a home-made tool
take a hack saw blade and grind the back side of it down so you only have a thin strip of metal with the teeth still on it.
use the teeth to catch the key and pull it out.
if that doesn't work, let me know and i'll explain how to change the lock.
Dec 27, 2008 at 9:20 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
