I can not remove the bolt holding the lower crankshaft sprocket that the timeing belt goes over. I am trying to remove the water pump and I am stuck at this point. Is the bolt holding the crankshaft sproket right or left thread?I am afraid of heat due to location. is there a trick?
Mar 13, 2010 at 3:17 AM
