1991 Pontiac Sunbird Can this car be driven without power steering
IGGYPOP
Steering problem
1991 Pontiac Sunbird 6 cyl Front Wheel Drive Automatic
The power steering hose has been removed as it had a three inch hole/ tear in it. The owner has not been able to replace it yet.
Is it ok on the car to drive it this way? I have read on Ask Yahoo that it depends on if the power steering fluid is used as lubricant for the steering gear box which I don't know if so on this car. What about the power steering pump with no fluid?
Thanks.
Oct 9, 2009 at 7:02 PM
  • 110,246 POSTS
Don't drive it like that. There is a good chance you will end up replacing the rack and pinion.
Mar 8, 2010 at 5:47 AM
