1991 Pontiac Sunbird almost start
160,000 MILES • 6 CYL • FWD • AUTOMATIC
KJEUDE
  • 9 POSTS
I have a 1991 pontiac sunbird convertable, recently it developed a "almost start" situation. Let me give tou some background. The car has a new fuwl tank, sender, pump and filter. new plugs and wires. The car will crank, and starts and idles for about ten seconds and dies. I can spray carb clean in the T.B. and it continues to run, so seems to be a fuel delivery issue. Any ideas as to a probable cause with all the new parts, what am i missing? Thanks for any help.
Mar 2, 2009 at 4:43 AM
  • 75,988 POSTS
I can spray carb clean in the T.B. and it continues to run-Does it continue to run or you have to be feeding it at all times for it to continue to run.
If the fuel pressure is correct-check the injector/s and get back with me.
Mar 2, 2009 at 4:54 AM
KJEUDE
  • 9 POSTS
[quote:23ebcebba9="rasmataz"]I can spray carb clean in the T.B. and it continues to run-Does it continue to run or you have to be feeding it at all times for it to continue to run.
If the fuel pressure is correct-check the injector/s and get back with me.[/quote:23ebcebba9]
Fuel prssuer between 41-45 psi. dies as soon as i stop spraying the carb clean. What should I use to check the injectore, just a noid to veryify signal or is there a resistance across the injector i should be looking for. I ask because i had a firebird 350 car that the noid lit up, but injectors still didnt fire. Drove me crazy. replaced them out of frustration.and it worked.
Mar 2, 2009 at 5:15 AM
  • 75,988 POSTS
Your fuel pressure is okay-What liter engine is this? I need this to give the injector/s resistances-Could be the injector/s what your doing is bypassing the injector/s if the computer is energizing the injector/s-the injectors is not in the circuit
Mar 2, 2009 at 5:26 AM
KJEUDE
  • 9 POSTS
[quote:9811a6b917="rasmataz"]Your fuel pressure is okay-What liter engine is this? I need this to give the injector/s resistances-Could be the injector/s what your doing is bypassing the injector/s if the computer is energizing the injector/s-the injectors is not in the circuit[/quote:9811a6b917]
Its a 3.1L
Mar 2, 2009 at 6:31 AM
  • 75,988 POSTS
Injector resistances is 8-12 ohms
Mar 2, 2009 at 7:24 AM
KJEUDE
  • 9 POSTS
I had two bad injectors. #5 was reading 1.2 ohms
and #4 was reading 4.1 ohms. two new injectors and it runs like a champ.
Mar 2, 2009 at 10:06 AM
  • 75,988 POSTS
Now you're back on the road, thanks for the donation and good luck.
Mar 2, 2009 at 10:10 AM
