1990 Pontiac Sunbird Timing
125,000 MILES • 4 CYL • FWD • AUTOMATIC
RGART64
The timing belt broke and I went to replace it but could not find any timing marks on the lower pulley and I would like to know how to set the timing.
Jan 7, 2008 at 7:44 AM
BMRFIXIT
  • 19,053 POSTS
[quote="rgart64"]Other Category problem
1990 Pontiac Sunbird 4 cyl Front Wheel Drive Automatic 125000 miles
The timing belt broke and I went to replace it but could not find any timing marks on the lower pulley and I would like to know how to set the timing.[/quote
Marks should be the plate clean it good and check again
just an advice replace water pump too
if you can
Jan 7, 2008 at 8:47 AM
