1990 Pontiac Sunbird Park lights
NANCYLEE04
Electrical problem
1990 Pontiac Sunbird 4 cyl Front Wheel Drive
Park lights stay on on the left side when car is running and go off when key is removed.
Jun 27, 2009 at 4:49 AM
JDL
  • 16,098 POSTS
Hello, I'd have to check ground and voltage circuits to the lites that stay on. The feed to the park lamps should come from the headlite switch, if the headlite switch is turned off, there shouldn't be any voltage on that circuit. My info shows the feed to the headlite switch is hot all the time, got nothing to do with the ignition switch. Check for voltage on the wires going to the bulb sockets, let us know the color of wires with voltage.
Jun 27, 2009 at 5:57 AM
