1990 Pontiac Sunbird Fuel pump fuse problem
1990 PONTIAC SUNBIRD
245,000 MILES • 4 CYL • FWD • AUTOMATIC
RHUYARD
I have a problem with my fuel pump fuse keeps blowing out i had the fuel pump replaced and had the car at the garage a couple of times they can,t find the problem. there seems to be a short someplace but cant find where it is.the problem started the day i had replaced the heater core. I also had put in a new head gasket a couple weeks before the problem started.
Mar 27, 2008 at 9:12 AM
MASTER TECH DAN
  • 83 POSTS
you need to find a shop that main does just wiring you have a short or the ground/s were left off in one of the jobs done
Mar 27, 2008 at 9:19 AM
BLITZKREIGEN
Try looking behind the fuse box. It hinges down and swings toward you.( from the bottom ) If its not secure, the wiring behind it may work loose. the fuse for the fuel pump I think is top center of the box. Right where the hinge is.
May solve your problem, my wipers did the exact same thing, and thats all it was.
Blitzkreigen
Apr 27, 2008 at 5:19 PM
