while driving car shuts off, replace the ECM fuse and it starts and drives until it blows the fuse again - no rhyme or reason to what makes it blow
Have looked for grounded wires, pulled on wires, tapped relays, banged on the ECM - can't "make it happen"
additional info - infrequently you go to start it and you get nothing - wait awhile and it will start -
NOT HOT STARTER will jumper
also car was overheated before ECM problem but No Start problem is older
Thoughts? Help? Direction?
Jun 29, 2010 at 11:46 AM
