1989 Pontiac Sunbird Engine Stalls
JACKDUP
  • 1989 PONTIAC SUNBIRD
  • 4 CYL
  • FWD
  • 200,000 MILES
My daughter said her car was stalling on occasion. I assumed it was probably just coming to a red light and if the RPMs dropped a little too much the engine stalled however that is not the case.
I drove it last night and while driving at about 30 the engine just died. I wasn't under load but the engine would not have been at idle either. I stepped on the gas and there was nothing. The check engine light was on but don't know whether it came on before or after the engine quit. If it was after than it would be just like when you first turn on the ignition it lights just to verify it works. There is no code stored. It would not start immediately after it quit, but after waiting two or three minutes if fired right up and I drove it away. I only had a few blocks to drive so not sure how soon it would have quit again.
There was no warning that it was going to quit. No surging or pinging or any other problems, just died.
Would appreciate any ideas of what I could check first.
Thank you
Saturday, January 9th, 2010 AT 6:45 PM
  • 109,885 POSTS
Have you checked fuel pump pressure?
Monday, March 8th, 2010 AT 10:05 AM
JACKDUP
I think it is the fuel filter. We just changed it and will see in a few days if that fixes the problem.
Thanks for the reply
Wednesday, March 10th, 2010 AT 12:31 AM
