1988 Pontiac Sunbird ecu keeps dying
REDSUNBIRDMAN
Electrical problem
1988 Pontiac Sunbird 4 cyl Front Wheel Drive Automatic
I have had 7-8 modules in this car in just 7 years! Yesterday it died again on the road, then restarted and started smoking, couldnt trace the cause, I recently rebuilt everything from the block up. Any ideas. It has had a bad miss from even before I put a new distributor and head on it.
thanks
Sep 9, 2008 at 4:05 AM
DOCFIXIT
  • 18,828 POSTS
What color is the smoke? Did it continue smoking after restart?
Sep 9, 2008 at 4:21 AM
REDSUNBIRDMAN
Hi and thanks for getting back so soon.
The smoke which was fairly white(sounds like water), mostly had stopped by the time I limped it back to work. I did find no. 1 plug was in bad shape-kinda crumbly near the electrode.
Sep 10, 2008 at 4:37 AM
DOCFIXIT
  • 18,828 POSTS
I suspect a headgasket failure the stuff on # 1 plug is probably antifreeze.
Sep 10, 2008 at 5:29 AM
