1987 Pontiac Sunbird Horn button
1987 PONTIAC SUNBIRD
37,000 MILES • 4 CYL • 2WD • AUTOMATIC
TONYMONASTRA
This vehicle has a horn button on each side of the steering wheel. what do you have to do to replace this horn button. Have found a new horn button from a pontiac dealer that was going out of business
Jan 18, 2010 at 9:43 PM
2CARPRO JACK
  • 11,533 POSTS
You will need to remove the stering wheel cover to gain access to the horn buttons.If air-bag equipped, disconnect the battery and let the vehicle sit for at least 10 minutes, then you will need to look at the back of the steering wheel for the holes to access the release or screws holding the center in the steering wheel
Jan 19, 2010 at 5:59 AM
