1988 Pontiac Station Wagon brake troubles
10,000 MILES • V8 • 2WD • AUTOMATIC
SAFARI1988
  • 8 POSTS
ok my brakes don't work 100% so i took the lid of the brake resivour and with it off pressed the brakes all the way down and it almost drained the front compartment so my question is did this help,do nothing or make it worse
Aug 27, 2009 at 9:25 AM
  • 75,988 POSTS
It made it worst-what you did there is you let air in the brake system-Bleed the brakes from R/R,L/R,R/F,L/F while bleeding keep an eye on the fluid level don't make it go down-
Aug 27, 2009 at 10:21 AM
