2006 Pontiac Solstice door latch
22,000 MILES • 4 CYL • 2WD • MANUAL
PAULTG
interior door latch does not work but exterior handle does. How do I removed the interior door panel to access the linkage
May 30, 2009 at 5:42 AM
  • 110,248 POSTS
Basically, you remove the arm rest and any screws that are holding it in place. After that, the panel is attached to the door with clips. Carefully pull them apart so they don't break.
Apr 26, 2010 at 6:38 AM
