1986 Pontiac Parisienne won' start
1986 PONTIAC PARISIENNE
BALL5740
Engine Mechanical problem
1986 Pontiac Parisienne V8 Front Wheel Drive Automatic
car won't start. ignition coil changed.
Jun 25, 2010 at 1:43 AM
Do below to determine if its a fuel or spark related issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 25, 2010 at 1:46 AM
