1986 Pontiac Parisienne carburetor idle cam sticking
1986 PONTIAC PARISIENNE
250,000 MILES • V8 • 2WD • AUTOMATIC
TOM IN ATHENS
Idle cam sticks on an E4MC carburetor so that the engine does not idle down when warmed up. No amount of tapping accelerator helps. Choke pull off has been replaced and works fine. Any suggestions appreciated. Thanks - Tom
Mar 24, 2010 at 4:19 AM
HMAC300
  • 48,601 POSTS
take some choke cleaner and spray all around the cam. Then open the throttle up abit and physically move it up and down and spray with choke cleaner once more. Do this until it moves freely . That should cure it.
May 1, 2010 at 12:25 PM
