1992 Pontiac Grand Am Misfire and Hot Cat
PONTIAC
DWHITE
  • 14 POSTS
I bought a 92 gran am 2.3 quad single cam . it runs but it misses,it spits back(missfires),dies when put in gear..I put new timing chain on . The timing marks were correct position when I took the chain off and put the new one on. It didn't change a bit . I started it and let it miss spit and gurrgle for about 16 minutes the other night and the cat was glowing red.! I jumped the A - B terminals to retrieve the codes but all it did was blink once then twice (diagnostic mode). should I let it blink more than 5 or six times ? I never got anything out but the one code? Could it be a partially plugged cat? Or a problem with the coil ? Any suggestions will help. I am getting ready to make a flower pot out of it so hurry. also , the car sat for two years . Would the gas in the tank cause this much trouble?
Mar 20, 2007 at 11:02 AM
MIKE H R
  • 3,094 POSTS
if the cat conerter got red hot i would think the place to start is replacing the cat converter, the glowing red is from a clogged converter. that could also be your problem with the miss fire, because of the back pressure.
Mar 20, 2007 at 11:55 AM
DWHITE
  • 14 POSTS
[quote:53a3cc174f="M_J_RITZEL"]if the cat conerter got red hot i would think the place to start is replacing the cat converter, the glowing red is from a clogged converter. that could also be your problem with the miss fire, because of the back pressure.[/quote:53a3cc174f]
thank you.I will check out the cat tomorrow and get back to you. Man you guys are fast
Mar 20, 2007 at 12:07 PM
MIKE H R
  • 3,094 POSTS
We do the best we can
Mar 20, 2007 at 12:15 PM
2CARPRO JACK
  • 11,533 POSTS
Might also want to try a new coil housing if it hasnt been replaced before. It acts as the plug wires
Mar 21, 2007 at 12:58 AM
DWHITE
  • 14 POSTS
I checked the coil housing with an ohm meter from coil contact point to point of contact with spark plug . 1 and 3 were infinate but 2 and 4 were 16. shoudn't the all be infinate (pegged out on the meter)?
Mar 23, 2007 at 10:59 AM
Suggested Repair
Inspect and replace the catalytic converter if it is restricted, since a red-hot converter points to clogging and exhaust backpressure that can cause misfire and stalling. Also test and replace the coil housing if it is original, because it serves as the plug wires and the reported resistance readings are inconsistent.
Conversation Summary
The owner of a 1992 Pontiac Grand Am 2.3 reported misfiring, spit-back, and stalling in gear after the car sat for two years. A new timing chain installed with correct marks did not help, and the catalytic converter glowed red after running. A reply attributed the glow and misfire to a clogged converter and backpressure, while an expert also suggested replacing the coil housing if original. The owner later measured uneven coil-housing resistance and asked about old fuel and diagnostic blink codes.
