timimg or cat converter problem?
PONTIAC
DWHITE
  • 14 POSTS
I bought a 92 gran am 2.3 quad single cam . it runs but it misses,it spits back(missfires),dies when put in gear..I put new timing chain on . The timing marks were correct position when I took the chain off and put the new one on. It didn't change a bit . I started it and let it miss spit and gurrgle for about 16 minutes the other night and the cat was glowing red.! I jumped the A - B terminals to retrieve the codes but all it did was blink once then twice (diagnostic mode). should I let it blink more than 5 or six times ? I never got anything out but the one code? Could it be a partially plugged cat? Or a problem with the coil ? Any suggestions will help. I am getting ready to make a flower pot out of it so hurry. also , the car sat for two years . Would the gas in the tank cause this much trouble?
Mar 20, 2007 at 11:02 AM
MIKE H R
  • 3,094 POSTS
if the cat conerter got red hot i would think the place to start is replacing the cat converter, the glowing red is from a clogged converter. that could also be your problem with the miss fire, because of the back pressure.
Mar 20, 2007 at 11:55 AM
DWHITE
  • 14 POSTS
[quote:53a3cc174f="M_J_RITZEL"]if the cat conerter got red hot i would think the place to start is replacing the cat converter, the glowing red is from a clogged converter. that could also be your problem with the miss fire, because of the back pressure.[/quote:53a3cc174f]
thank you.I will check out the cat tomorrow and get back to you. Man you guys are fast
Mar 20, 2007 at 12:07 PM
MIKE H R
  • 3,094 POSTS
We do the best we can
Mar 20, 2007 at 12:15 PM
2CARPRO JACK
  • 11,533 POSTS
Might also want to try a new coil housing if it hasnt been replaced before. It acts as the plug wires
Mar 21, 2007 at 12:58 AM
DWHITE
  • 14 POSTS
I checked the coil housing with an ohm meter from coil contact point to point of contact with spark plug . 1 and 3 were infinate but 2 and 4 were 16. shoudn't the all be infinate (pegged out on the meter)?
Mar 23, 2007 at 10:59 AM
