nomenclature of the ignition module
PONTIAC
TBR
hi, i have a pontiac boneville v8 1974 and i lost the correct order of ignition module, i will thank u any help
Feb 26, 2006 at 6:07 AM
PEPPERMRJ
  • 1,158 POSTS
Don't understand your question. Are you looking for the firing order of the spark plugs?
Post back. :?:
Feb 26, 2006 at 6:17 AM
TBR
i'm sorry my english is not so good, it's about the correct order wiring at the exit of ignition module
Feb 26, 2006 at 11:32 AM
PEPPERMRJ
  • 1,158 POSTS
Your English is a lot better than the languages I don't speak. :) Where are you from?
I am guessing that by ignition module you mean the distributor cap. Here is a link that I hope helps. It shows the firng order and distributor layout for different 1974 pontiac trans am engines. Figure 4 should be what you need.
They should be the same as your Bonneville.
Feb 26, 2006 at 12:10 PM
