Imputing anti-theft codes 4 radio
PONTIAC
WALTWILKITIS
2000 Pontiac GranAm GT 80K. I need a new battery . When I disconect the old battery the anti-theft device in th radio will make it inoperable. I have the activation codes given to me by a Pontiac dealer when they had to activate it before. What I need to know is how and where do I imput these numbers.
Jun 28, 2006 at 3:43 AM
WALTWILKITIS
I found out how to do this.If you know yout code do the following:
1. turn key to [b:d6a97d8a0c]ACC[/b:d6a97d8a0c].
2. turn off radio
3. push and hold the [b:d6a97d8a0c]# 1 and 4[/b:d6a97d8a0c] buttons till [b:d6a97d8a0c]SEC[/b:d6a97d8a0c] appears
4. Push in [b:d6a97d8a0c]MIN[/b:d6a97d8a0c] button and [b:d6a97d8a0c]_ _ _ [/b:d6a97d8a0c]appears
5. push min button until last 2 numbers of your code appear
6. push hr. button until first 1 or 2 numbers appear.
7. when your code is showing push in the am/fm button to complete the task.
Use the same proceedure to re-activate the anti-theft .
No more than 15 sec can elasp between each procedure. If it does the radio will go back to SEC and you must start over.
Jun 28, 2006 at 9:22 AM
