Gas mileage for 1985 Pontiac parisienne
1985 PONTIAC
1985 PONTIAC
I have a 1985 pontiac parisienne station wagon. Recently I replaced everything under the hood. Remanufacatured engine, transmission, starter, spark plugs and high tension wires, distributor, radiator and hoses, power steering pump, fuel pump and egr. I also replaced the catalytic converter. But my problem is my gas mileage is 10 miles/gal. What am I missing? It's running great but only the gas mileage is worse than before I replaced everything under the hood..
Thank you in advance for any advice you can give me.
Feb 8, 2007 at 6:37 AM
  • 55,682 POSTS
first check the compression and compare it to factory spec's then check the fuel air mixture with a gas analyzer to see if the mixture is to rich. also check the ignition timing.
Feb 15, 2007 at 3:38 AM
