engine surges when cold
PONTIAC
BOBHINES821
it has gone progressively worse, when the engine is cold ie 20 degrees fahinheit to 40 degrees fahinheit, the motor surges to 3000rpm and back to 500rpm, very quickly till the motor warms up ,and now has no power going up hills, it has gotten to the point when its cold it just nows rough idles and stalls,and will not rev up,its donebeing drivable{towed home}either its egr valve or throttle position sensor and o2sensor? please help me could it also be coolant temp sensor thank you for your help thanks bob hines
Mar 18, 2007 at 1:04 PM
BOBHINES821
1994 pontiac grand prix gt 3.4 egr valve never replaced,o2 changed at 75000,car now hows 130,000 mile on it, surges when cold has gotten progressively worse and now spits back thu intake and won't run at all. was towwed home today,also when warmed up would run fine but have no power thank you for helping me with this problem bob hines THANKS
Mar 18, 2007 at 1:24 PM
