2006 Pontiac GTO Engine Squeal
PONTIAC
JIMD
I have a brand new 2006 Pontiac GTO 6.0L, auto, with 1010 miles on it. I recently installed a K&N air charger system in it. After following the instructions provided with the K&N kit I took the car out for a test drive. I found that everytime I applied gas that the engine makes a squealing noise, much like a loose fan belt. This noise did not exsist prior to the installation. I have tightened all the brackets for the hoses, re-adjusted the angle of the tube, everything I could think of. The clearence for all the brackets, intake tube and wires for the sensor are fine, no rubbing any where. I even removed the system and re-installed it and I still get this annoying sqweel. Any advice?
Sep 29, 2007 at 2:07 PM
MMPRINCE4000
  • 8,548 POSTS
You may have spilled some contaminate on the belt. KN filters are pre-oiled at the factory and some of the oil may have got on the belt.
I would take the belt off, clean the pulleys of with brake clean and install a new belt.
Nov 5, 2007 at 9:50 PM
Suggested Repair
Remove the drive belt, clean the pulleys with brake cleaner, and install a new belt. Pre-oiled K&N filter oil may have contaminated the belt.
Conversation Summary
The owner of a low-mileage 2006 Pontiac GTO installed a K&N air intake and then heard a belt-like squeal when accelerating. Checking clearance and reinstalling the system did not stop it. The expert suggested filter oil may have contaminated the belt and advised cleaning the pulleys and fitting a new belt.
