86 Pontiac Parisienne stalling
1986 PONTIAC
PARISIENNE86
86 Parisienne, 120K mi, 307 8cyl. When the car is cold, it starts and runs fine. After about 15 min, especially once I get it up to highway speeds, it begins to hesitate, then starts to cut out. If I take my foot off the gas, it will idle fine, but when I reapply the gas, it cuts out. I can milk it along for a while like this, but it eventually dies completely. The problem is much worse when climbing hills; once the car starts hesitating, even the slightest grades will make it want to stall. Once it's dead, if I sit for a few minutes, it will start and run fine for about 5 minutes. The longer I sit before starting again allows me to go further before it stalls. If I happen to stall on a steep hill, it is much more difficult to get it started again. There is a strong gas smell when the the engine stalls.
The exhaust system is new. I checked the distributor cap and rotor, and coil, and they are good. New sparks and wires. New fuel pump. New air and fuel filters. EGR diaphragm was leaking, so I disconnected the vacuum line and plugged it. New 02 sensor and computer. New PCV valve and breather, though there is not much vacuum at the breather.
Jan 14, 2007 at 10:38 AM
BUDDYCRAIGG
  • CAR REPAIR CONTRIBUTOR
  • 2,262 POSTS
I suspect the ignition module.
...gets worse when hot
... hard to climb hills
... smell gas
I understand the module is *kinda* working. and may even test good on one of those testers at a parts store.
But I truly think that is your problem.
Dec 7, 2008 at 8:04 PM
