2005 Other Pontiac Models replace a break light bulb
2005 PONTIAC
25,000 MILES • V8 • 2WD • MANUAL
JOHNBOY1940
I removed the 2 screws that hold the tail light assembly but the asscmbly will not come off I applied as mutch presure as I can withiut breaking the red lense tee car is a gto
Jan 29, 2008 at 2:21 AM
HMAC300
  • 48,601 POSTS
the bub base will twist out of the lens if you can reach it in the trunk, there may be a few nuts holding the assemply in. Once you get teh bulb base out then teh bulb pulls straight out... there may only be 2 or maybe 3 nuts holding the tailight assy in the car.
Feb 24, 2010 at 9:45 AM
