2005 Other Pontiac Models repairs?
2005 PONTIAC
EASYGOESIT
Brakes problem
2005 Other Pontiac Models 4 cyl Four Wheel Drive Automatic 19.k m miles
took car in for 20k oil change and was told i need
a) front caliper service b) service rear brakes & parking brake c) 4 wheel alignment.
Im 60 yrs old hardly drive car as u can c. It's 90% highway driving. And I avoid potholes most of the time.
The car is parked underground on level floor.
I feel like I'm being taken advantage of!
I have regularly had work done that is requested under the new cainstructions at particulat km points as layed out in manual. IE oil change, tire rotation.
Is the above repairs possible.
Apr 19, 2008 at 12:43 AM
MERLIN2021
  • 17,250 POSTS
At 20,000 miles, it's not impossible to need new brakes. As for the alignment, does it drive straight if you let go of the wheel?
Apr 19, 2008 at 1:25 AM
EASYGOESIT
[quote:e04881169a="merlin2021"]At 20,000 miles, it's not impossible to need new brakes. As for the alignment, does it drive straight if you let go of the wheel?[/quote:e04881169a]
Much thanks and yes it does drive straight.
Apr 19, 2008 at 4:11 AM
MERLIN2021
  • 17,250 POSTS
Alignment is probably OK then.
Apr 19, 2008 at 4:21 AM
