2004 Other Pontiac Models fan motor
2004 PONTIAC
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
PENCESL
The fan motor died. How do I install a new one in my 2004 Vibe?
Nov 5, 2008 at 4:11 AM
MMPRINCE4000
  • 8,548 POSTS
Before you put a new one in, disconnect the fan connector and connect the fan motor directly to battery, if fan runs, then the fan motor is OK and the problem may be fuse/relay/fan switch.
The fan is bolted to radiator, although the upper hose may have to be disconnected for clearance, but once unbolted, it lifts straight up.
Dec 13, 2008 at 11:18 PM
