2003 Other Pontiac Models
2003 PONTIAC
115,000 MILES • 4 CYL • FWD • AUTOMATIC
GRANT62
Water leaking under passenger side,under glove box.
Screeching noise when turning wheel. On a Pontiac Vibe
Sep 13, 2008 at 7:57 AM
MMPRINCE4000
  • 8,548 POSTS
If water, then a weather stripping issue probably on windshield. If coolant then heater core.
Screeching, is either a bad PS pump, or belt/belt tension. Check PS pump area and pressure/return lines for leaks, check belt tension and for any contamination on belt.
Mar 21, 2009 at 1:48 AM
