2003 Other Pontiac Models
GRANT62
  • 2003 PONTIAC
  • 4 CYL
  • FWD
  • 115,000 MILES
Water leaking under passenger side, under glove box.
Screeching noise when turning wheel. On a Pontiac Vibe
Saturday, September 13th, 2008 AT 2:57 PM
MMPRINCE4000
  • 8,548 POSTS
If water, then a weather stripping issue probably on windshield. If coolant then heater core.
Screeching, is either a bad PS pump, or belt/belt tension. Check PS pump area and pressure/return lines for leaks, check belt tension and for any contamination on belt.
Saturday, March 21st, 2009 AT 8:48 AM
