2001 Pontiac High Idle After Start
2001 PONTIAC
MICHELLEO
Idles high when started. Replaced intake manifold gasket, and cleaned fuel injectors, but idle starts at 3000 RPM, and then sometimes it kicks down , but sometimes it doesn't.
Jan 26, 2007 at 5:20 AM
MMPRINCE3000
  • 133 POSTS
An idle that high is almost always a vaccum leak. Did you replace the O-rings on the injectors?
Jan 26, 2007 at 9:30 AM
MICHELLEO
No, I did not try that. I replaced the intake manifold gasket, and found a small leak on the oil pump, so replaced that gasket, but nothing else. No new codes come up on the computer. I have heard it could also be clogged fuel injectors, vaccuum leaks, or a AC sensor. Have you seen this?
Jan 29, 2007 at 4:54 AM
MMPRINCE3000
  • 133 POSTS
Make sure the injectors are properly seated. You should be getting a code with an idle that high (when in closed loop).
The best way to diagnose this problem is to use a scanner and verify all sensors are in range.
If it idled properly before the repairs, then idled high afterwards, it is most likely the repairs caused it.
Jan 29, 2007 at 8:37 PM
Suggested Repair
Recheck injector seating and O-rings for a vacuum leak, especially if the high idle began after the intake work. Use a scanner to confirm all sensors are in range and that the engine enters closed loop.
Conversation Summary
A 2001 Pontiac idles around 3000 RPM after starting and only sometimes drops. The owner replaced the intake manifold gasket, cleaned the injectors, and replaced an oil-pump gasket, with no new codes. The expert said a vacuum leak is the most likely cause, asked whether injector O-rings were replaced, and advised confirming the injectors are seated and scanning sensors. If the idle was normal before the repairs, those repairs are the likely cause.
