2001 Pontiac Aztek Hard to Fill Tank
2001 PONTIAC
DEBORAHT
I recently had to replace my fuel filler pipe and my fuel pump. Just before going to the garage, I began to have difficulty filling my tank. After the repair, I still have difficulty filling my tank and it is also difficult to start my car each time.. I also smell gas after starting my car. I do not have a light on in the panel to suggest getting it serviced, so I assume there is no code registering. At a loss as to what it could be. Please advise
Apr 27, 2007 at 11:55 AM
GMTECH
  • 537 POSTS
You could have a problem with your vent valve. If it isn't working it can be difficult to fill your tank. You should check your fuel filter. It can cause starting problems as well as the smell. Have you had it to a dealer lately? There is a recall on the fuel tanks. They will check it out for free I think.
Oct 24, 2010 at 1:10 PM
Suggested Repair
Check the fuel tank vent valve, which can make the tank hard to fill if it is not working. Also inspect the fuel filter, which can cause hard starting and a fuel smell. Have a dealer check the fuel tank recall, which may be inspected at no charge.
Conversation Summary
The owner of a 2001 Pontiac Aztek replaced the fuel filler pipe and fuel pump but still has trouble filling the tank, hard starting, and a gasoline smell after startup, with no warning light. The expert suggested a faulty vent valve, a fuel filter problem, and a free dealer check of a fuel tank recall.
