1999 Pontiac Firefly: Low beam headlights don't work
1999 PONTIAC
SUBGRAPP
Mileage: 140, 137 km
Engine: 1.0 L, 3-cylinders
I just purchased this vehicle as my daily driver. I bought it for a good deal but it needs a few things...one being low beam headlights. The day time running lights and the high beams work just fine.
Any help would be much appreciated.
Thanks,
-Matt
Jun 21, 2007 at 7:02 AM
TBDK
  • 24 POSTS
Were the lights not working when you bought the car or did they go out after? It is possible(having done it) to blow the low beams and leave good high beams. Very slim chance of doing them both at 1 time though. If they came blown then you should just have to replace the low beams. If they went out on you then check fuses and wiring. Make sure the bulbs are securly in. Hope this helps.
Jun 22, 2007 at 2:39 PM
SUBGRAPP
Thanks for the reply...the low beams were not working when the car was bought. I will try the things you suggested.
Jun 24, 2007 at 3:28 PM
