1996 Other Pontiac Models
1996 PONTIAC
MIKERITCHIE
Engine Performance problem
1996 Other Pontiac Models 6 cyl Front Wheel Drive Automatic
The car has a 3800 egn. with sopercarger it is will not hold coolant I have press. test the sysetm & it holds press. find no leaks .
May 8, 2010 at 3:25 AM
HMAC300
  • 48,601 POSTS
retest your system or have apro do it. if you are losing coolant then it's got to be a head gasket/intakeleaking. It could also be your radiator as well. to check that let your car get hot and shutit off. disconnect the electric fans and feel the radiator all over. if you feel any cold spots it's bad as it should be the same temp all over, not cold in one spot and warm in the other....
May 23, 2010 at 8:04 AM
